I downloaded VirtualDub, however I have no file type "DirectShowSource" available to me. As far as the open filetype options, .mp4 is not supported?pantti wrote:You can use Virtualdub to convert mp4s to some other format. Drag and drop won't work. You must manually select file type "DirectShowSource" in open dialog to successfully open mp4 file.
Well I appreciate the help, but after it created the 47GB avi file, it must not have buffered the audio correct as it cuts out every 1/2 second and looks awful as far as compression (and the file is almost too large to even work with).pantti wrote:Oh I forgot Vdub needs plugin to open Direct Show videos.
This is our priority at the moment about Action!Pyrex wrote:Ghost I appreciate the reply. I know the team is hard working on the next patch and I'm happy to hear we will have a format we can work with. I know it's the question you probably won't be able to answer, but is there any ballpark on when this update will happen? Are we talking weeks or months?
