are you using it with recent drivers? because i can only use it with very specific drivers from a year and a half ago, if i use anything newer it stops working, same symptoms as the user above me, plus quick sync got a significant improvement, specially in quality in recent drivers so it would be good for the mirillis team to update action to work with newer drivers, year and a half is quite outdated, remember that not many people will have the patience to search every single post about action and quick sync, i was about to give up on using action after trying several drivers, until i saw a post from a user that pointed me which drivers was the one working.radi wrote:I'm using IQS every day and does not experience any issues with it. What issues do you experience?
Which post is that because I'm having issues aswell.Krelian wrote:are you using it with recent drivers? because i can only use it with very specific drivers from a year and a half ago, if i use anything newer it stops working, same symptoms as the user above me, plus quick sync got a significant improvement, specially in quality in recent drivers so it would be good for the mirillis team to update action to work with newer drivers, year and a half is quite outdated, remember that not many people will have the patience to search every single post about action and quick sync, i was about to give up on using action after trying several drivers, until i saw a post from a user that pointed me which drivers was the one working.radi wrote:I'm using IQS every day and does not experience any issues with it. What issues do you experience?
http://www.guru3d.com/files-details/int ... nload.htmlThe Renegadist wrote:Which post is that because I'm having issues aswell.Krelian wrote:are you using it with recent drivers? because i can only use it with very specific drivers from a year and a half ago, if i use anything newer it stops working, same symptoms as the user above me, plus quick sync got a significant improvement, specially in quality in recent drivers so it would be good for the mirillis team to update action to work with newer drivers, year and a half is quite outdated, remember that not many people will have the patience to search every single post about action and quick sync, i was about to give up on using action after trying several drivers, until i saw a post from a user that pointed me which drivers was the one working.radi wrote:I'm using IQS every day and does not experience any issues with it. What issues do you experience?
