djmerete98
PC Specification: Windows 8.1
Help with "Critical Error 103"
Fri Jul 10, 2015 5:44 pm
Every time I try to open the application is says "Critical error 103: Failed to initialize product. Please try reinstalling." but every time i try to reinstall it, it gives me the same error. Is there anything specific i have to do to fix it or install it in a special way? Thanks!
yareth alejandro
PC Specification: windows 10 2GB DDR3 64 bits
Re: Help with "Critical Error 103"
Wed May 11, 2016 9:19 pm
oye ya te soluciono el problema?
Fri May 13, 2016 5:57 pm
Critical error 103 occurs if Action! cannot identify one of its files due to lack of digital signature or one of the file is not compatible with current version. Please try following steps below to completely re-install Action. You will need your serial number to activate your product again.
1. Uninstall Action!
3. Remove Action! catalog.
4. Reboot your PC.
5. Install Action! again. Make sure that your installer file comes from official website - www.mirillis.com (if you have not purchased Action! through Steam).
Users browsing this forum: derlean and 6 guests
