wesmoen
PC Specification: i7-2600k, GTX970, Windows 8.1 Pro x64
Don't get an export window, after clicking "Export video"
Wed Jul 15, 2015 5:41 am
Hello there, I'm enjoying Action immensely but since a certain version I have some problems to export my videos to MP4. After clicking "Export video" I usually get an export window. I believe since 1.25, it doesn't show up anymore. I tried to find the window via alt-Tab, but with no success.
I had the idea I was the only one, but a friend of mine who also uses action have the same problem. We both use different Windows versions and hardware. So, what can it be?
I tried closing programs as Teamviewer and such on both computers, in hope that it would be solved, again no success.
My setup:
Windows 8.1 Pro x64, i7-2600k, GTX970.
his setup:
Windows 7 Ultimate x64, i7 (Not sure which model), GTX580.
Re: Don't get an export window, after clicking "Export video
Wed Jul 15, 2015 11:25 am
Did you recently used more than one computer screen?
wesmoen
Thu Jul 16, 2015 8:08 pm
Not recently, but I do work with two computer screens for several years now, even before using Action. The disappearing export window is since a recent version. I exported video with two screens before. Could change in Video driver or video hardware have such an impact on action?
wesmoen
Sat Aug 01, 2015 6:15 am
An quick update: Apparently, It helps to uninstall Action AND to remove the program from register. After installing it again, it works like it should again!
