CRAZEH247
PC Specification: FX8350, R9270X, Windows 8.1 Upgrade
BIG ISSUE! AVI setting records MP4 after latest update!!!
Sun Jul 19, 2015 7:12 pm
Action Version: 1.25.5.0
Recording Resolution: Original
Recording Mode: Game
OS: Windows 8.1
GPU: AMD R9 270x 4GB
Drivers: Latest
CPU: AMD FX8350@4.0GHz
Mobo: Asus Sabertooth 990FX R2.0
Memory: 8GB@1866MHz
Monitor Resolution: 1920x1080
Game/App/Screen Problem: Every game and Every screen recording
Description: After updating to the latest version i.e. 1.25.5.0, the video recordings no longer record in AVI format... and records in MP4 instead. It also seems to be making the games drop in framerate by a really big amount whilst recording now than it did on the previous version. The recording setting is Original resolution and 60FPS and AVI, but the video still records in MP4. I tried changing to MP4 and MP4 [AMDAPP] settings and they record like normally, but switching back to AVI still gives me a MP4 video recording!
The MP4 recording is also MUCH WORSE in quality than the AVI recordings I was doing. I know this because I played a mission that I recorded just a few days ago on DMC4 and recorded the same mission again. Then played them both back to back and I can see the clear difference in the horrendous quality on the MP4 version.
Because of this issue, I've had to stop using the program since the update because it's suddenly making the games perform terribly even though before they weren't with the same settings and the fact that the video recording quality has changed because it's recording in MP4 now for some reason even though I have got the settings to record it in AVI.
I've tried recording all the types, screen capture, game capture, and the freeform capture and they all do the same thing. They all are doing MP4 recordings despite the settings.
Please I need a fix for this as it's stopping me from using the program to record more videos. Why has this happened and what's the solution for this? Do you guys know of this issue and have other people had it too?
Re: BIG ISSUE! AVI setting records MP4 after latest update!!
Fri Jul 24, 2015 9:38 am
Disable LIVE streaming feature and next time use search instead of post.
CRAZEH247
Fri Jul 24, 2015 4:59 pm
Oh, thanks.
I was gonna search first but I made a bad assumption that maybe nobody except me had the issue. Sorry. Thanks for solving the issue, it worked!
I apologise for posting two threads of the same name and issue as well, I thought my first thread post wasn't approved so I made a second one. Please delete both threads that I created of the same issue if there is a solution already existent on this forum and accept my apology.
