Drevlikdehgamer
PC Specification: Quad-core · Intel CPU, Geforce GTX 750
Gameplay recording w/ Face-Cam, and Microphone Sync
Wed Jul 22, 2015 2:42 am
I discovered problem not to long ago, after exporting a video, and it seems that my game play is no longer in sync with with my webcam, and it's microphone. I was wondering if this has do with memory. Or is it just the because of the webcam becoming faulty. One thing is for certain, when I tried to work around the problem by muting the voice recording. I run into another problem, and that's when my exporting always stops at 61%. I'm wondering if I have to reinstall Action!. If that's is the case I would, unless there is any other choice that would be a good way to fix without waiting for the installation process to happen.
Re: Gameplay recording w/ Face-Cam, and Microphone Sync
Fri Jul 24, 2015 9:18 am
Does your issue occurs only when webcam is recorded? Is there any chance to test the same case with another webcam?
Drevlikdehgamer
Sun Jul 26, 2015 10:37 am
Okay so I tried it without the Webcam video recording on. And tried it with the webcam's microphone only. That seemed to do the trick. But in order to try a different webcam would be to buy a new one, unless I could get some decent explanation why the webcam isn't working like it is anymore. I've recorded 10-15 videos with my webcam, and action in the past.
So could it be the webcam's software?
Is there a way to set Action! to system default? Could that work?
