alvanosGR
PC Specification: Windows 7 64 bit, intel i5
action! with sony vegas
Wed Jul 29, 2015 4:51 pm
hey there,
i have action full version but my monitor's resolution is 1280x1024 .
My problem is, i record league of legends , AVI , 720p, 60 framerate and when i add it to vegas pro 13.0 to render it 1080p for youtube it doesn't render it. It makes it worst in quality and resolution.
How can i fix this ?
I only want to record games with action, add them to vegas and render at 1080p.
ItsReneee
PC Specification: Windows 8
Re: action! with sony vegas
Sun Sep 13, 2015 10:12 am
Well your original video quality is 720p if you render it in 1080p sony vegas will like you said mek the worst quality because the the original video is 720p and you wish to render it in 1080p it has to make more pixels and the video bigger.And by doing that the qualitiy gets messed up.It's like trying to make an 800x800 image 1200x950 in photoshop.The result will always be blurry,low quality.You can't make a lower quality image or video in higher quality without getting it blured and ugly.There are 2 solutions:
solution 1:Get a bigger monitor for 1080p vids you need a monitor atleast with 1920x1080 pixel.I have A 24 inch one with 1920x1080 pixels and the quality is amazing!
solution 2:In sony vegas render the video in 720p
Hope this helped! :D
-Rene
