mopkins
PC Specification: i7-3770, Win 7 64bit, Dual SLI nVidia 1
Error on Startup
Thu Jul 30, 2015 1:27 am
Hey,
I'm having an issue when starting up Action! The splash screen appears and then I get an initialization error suggesting I reinstall. Once I reinstall and re-enter my activation key it works fine. After using it, I exit the program normally and then get the windows 'This program has crashed' message, then If i try to re-open, i get the first error again.
Is there a fix for this? It's pretty annoying to have to reinstall the program every time I want to use it.
Re: Error on Startup
Fri Jul 31, 2015 3:39 pm
I'd suggest to contact our support team directly via support@mirillis.com.
