mopkins
PC Specification: i7-3770, Win 7 64bit, Dual SLI nVidia 1
Error on Startup
Thu Jul 30, 2015 1:29 am
Hey,
I'm having an issue when starting up Action! The splash screen appears and then I get an initialization error suggesting I reinstall. Once I reinstall and re-enter my activation key it works fine. After using it, I exit the program normally and then get the windows 'This program has crashed' message, then If i try to re-open, i get the first error again.
Is there a fix for this? It's pretty annoying to have to reinstall the program every time I want to use it.
Re: Error on Startup
Thu Jul 30, 2015 11:08 am
Is there any number code associated with your error message?
mopkins
Thu Jul 30, 2015 12:06 pm
It seems that the error has resolved itself. If it happens to come back i'll be sure to let you know :)
Thanks.
