Soboy
PC Specification: Windows 10
[Suggestion] Automatic file splitting
Mon Aug 03, 2015 3:56 am
I came across an issue with splitting audio streams from very large recordings, using right click > Extract Audio Stream or using VirtualDub, where it will only export a portion of the audio and leave the end behind. I ended up having to split the AVI into multiple pieces to get the audio streams out in full. A feature like in fraps to automatically split the recording after a certain interval would be very helpful. :)
Thanks!
