marciomachida
HOW to open .mp4 in Sony Vegas
Mon Aug 03, 2015 2:02 pm
Hello!
I upgraded my pc to Windows10, so I'm downloading everything again.
When I use Action + Sony Vegas, I can import .avi files properly, but .mp4 files only show only AUDIO in Sony Vegas.
So, I downloaded something or change some configuration to import .mp4 files recorded with Action to Sony Vegas (AMP APP, .mp4).
But now, with windows 10 I don't remember exactly what I need to do to import all the layers (video + audio1 + audio2) to Sony Vegas, currently I can only import .mp4 files with no VIDEO, only AUDIO.
I had the same problem before and I solved it, but I forgot how.
I tried:
- Install QuickTime.
- FFdshow.
- XVid codec.
marciomachida
Re: HOW to open .mp4 in Sony Vegas
Mon Aug 03, 2015 2:52 pm
SOLVED.
HERE IS THE SOLLUTION (works for me): https://www.youtube.com/watch?v=f5n6IeBCw3A
hej
Fri Feb 26, 2016 5:37 am
That's not solution. If you pay close attention in Sony Vegas project properties you will see FPS being reported incorrectly, typically reading 100FPS though that may vary.
The proper workaround is to remux the video into a different container.
The proper solution is for Mirillis to release an update that fixes a bug they introduced in a previous version.
ShadowQQ
PC Specification: windows 7
Fri Mar 09, 2018 5:48 am
This video may help you https://www.youtube.com/watch?v=yb14cKgb6WE by the way, MP4 is the Sony Vegas supported format, so if you can not import MKV to sony, I can understand, but for mp4, I have no idea, anyway, hope this video is useful.
