michach
PC Specification: i7-4790K,GeForceGTX980,16GB RAM, Win8.1
After an update to Windows 10, the sound recording no longer
Mon Aug 03, 2015 4:12 pm
After an update to Windows 10, the sound recording no longer works.
The settings in action! are the same as before the update.
With a click on the movie in Action, it appears, but without sound.
When I open the .avi file directly using Windows 10 player, I have no picture and no sound.
When I open the file with VLC Player, I have the picture, but no sound.
In the settings of Windows -> I have a level when I speak into the microphone.
In the microphone settings of Action! I tested it with the system settings and directly with my sound card.
I have the version 1.25.6.0 installed.
Can you help me out here, or are these problems already known?
thanks
Danke
