Mamokin
PC Specification: Intel Core i7 3820, Windows 10,GTX 660Ti
Record/Livestream Stops on Window resize.
Sun Aug 09, 2015 2:35 pm
I have been loving Mirillis Action but I am hating that I cannot stream or even change my window size if I record. So far I have primarily recorded Minecraft with it and have no issues anymore with Action! other then this.
I performed a test livestream to YouTube and all was well but as expected, if I changed the window size of Minecraft the recording/stream stops. This same issue occurs when just recording Minecraft.
I record Minecraft via the Games and Applications (DirectX/OpenGL) recording mode as it is the only way to capture a window. I would much rather have a solution to this problem than to have to use OBS again so that I can capture the window efficiently and still be able to do other things on my computer without the recording or stream dropping because I made the game an inactive window for a few seconds.
