schemer
PC Specification: Win10 Pro 64, i7 2600K, Nvidia GTX1080
Problem with copying video from second monitor
Wed Aug 12, 2015 6:05 pm
I used to be able to copy videos from my second monitor and now I just get a copy of the first monitor's desktop and no video. I also started getting an error message stating:
Nvidia Streamer User Agent has stopped working
I disabled that as it is for the Nvidia Shield (I do not have or use it). What is most likely the problem? I am using the "active desktop region" setting as I normally do. I also got the latest version of Action! and all the latest Win7 updates today. The only other thing I can think of is my monitor software (DisplayFusion Pro 7.2).
Thanks,
schemer
schemer
Re: Problem with copying video from second monitor
Tue Aug 18, 2015 1:26 pm
I wanted to say I fixed it shortly after I posted (waiting for moderator approval of post) by using the F8 key to switch active desktops (or monitors). I couldn't edit or delete my post as it was not available while I waited.
Thanks,
schemer
