Alexmtm
PC Specification: w8.1 i7
!Action get stuck after game recording more than few mins
Fri Aug 21, 2015 12:26 am
OS: Windows 10
Video Card: gtx 780
Memory: 16 GB
i7 4790k
Monitor Resolution: 1920x1080
Video Editor: -
Game Problem: available for all games
Video Type: MP4 and AVI
DxDiag: http://pastebin.com/7XdiDNAx
2 updates for windows 10 and still the same problem; during game recording mp4 intell quick synk, if I'm trying to record more than 10minutes Action! is showing me he still recording but if i stop recording and I get out of my game, the software is freezing with the white R on the taskbar and is not responding and i lose entire recorded video. This software is still buged for windows 10 x64 default install because is doing same thing on 2 different pcs. (is stucking after 1-2hours of mp4 acceleration + 60fps game recording)
Kurohh
PC Specification: To be updated
Re: !Action get stuck after game recording more than few min
Fri Aug 21, 2015 11:42 am
Hmm.
Tell me, do you get the little green down arrow with a hard-drive icon?
That is where my Action! is getting stuck at:
Alexmtm
Sat Aug 22, 2015 1:53 am
I'm recording in Gaming mode so I can't see the Action main pannel but I don't believe I have that hdd icon. For the moment is not stucking because I didn't minimized Action to the taskbar and I fixed him to the second monitor to check in real time during recording..
Dobs
Sat Aug 22, 2015 10:59 pm
Yep! Exactly...stop record, gives you the saving to HD arrow and BLAMO you are done and your video is corrupt.
Lovely! eh!
Alexmtm
Sun Aug 23, 2015 12:01 pm
yes
Alexmtm
Tue Aug 25, 2015 7:59 pm
Action! 1.26.1 AVI 1080p 60fps, video quality High, Use hardware acceleration IntelR, (no split videos): Big files recorded are corupted. Example: for 60 minutes !Action saved 1 hour and 40 minutes in slow motion, sound is bugged many times.
Same settings but if I record 1 minute, video+audio is fine. I made many avi records, less than 20 mins each and there is a chance that a video can freeze many seconds from 70% when I start watching, dunno if its another bug or codeck problem.
MP4 IntelR quick sync same settings 60fps : 1 to 30 minutes, video+audio is fine. I'll try to record 1 or 2 hours of high action game to check if works properly.
Alexmtm
Wed Aug 26, 2015 1:02 am
:evil: wate of time, another 1 hour and a half of corupted mp4 60fps. I'm gonna use something else to record in games because !Action drive me crazy.
Fri Aug 28, 2015 2:00 pm
Alexmtm
Fri Aug 28, 2015 2:05 pm
k thanx
