bathacker
PC Specification: Intel i5, AMD Radeon, R9 200, Win 10
Still after 1.26, not all game audio recording
Fri Aug 21, 2015 1:27 am
In-game sounds record but chat no longer records. I primarily play iRacing and all sound settings are set to Corsair audio -- same as system audio settings and Action!. The previous update before 1.26 broke the audio.
system audio.png (53.5 KiB) Viewed 7847 times
Re: Still after 1.26, not all game audio recording
Fri Aug 21, 2015 2:58 pm
Try changing to System Default instead of your current setting in Action.
bathacker
Fri Aug 21, 2015 3:03 pm
radi wrote:Try changing to System Default instead of your current setting in Action.
All to System Default even microphone? Previous versions the microphone wouldn't record unless the mic was specified.
bathacker
Sat Aug 22, 2015 3:51 pm
Just recorded with all sound settings on System Default and still issues with in-game chat. I captures mine but not from others.
bathacker
Sat Aug 22, 2015 8:33 pm
The lack of support in this thread is difficult to see. We opted for "the ultimate capturing software" and "most advanced recording software" and when we have issues, we get a half hearted response with no follow up. I am a paying customer.
Thankfully I was able to resolve my own issue by continuing to enable and disable features until something finally worked. Anyone having issues with 1.26 and in-game chat not recording, select "Allow multi-channel recording" and that should restore the broken feature.
Does Mirillis know that gamers have many choices when it comes to screen capture software? Asking for basic customer support should not be this hard. You need loyalty and gamers want products that work and that listen to the community. I hope you guys recognize that sooner than later.
