TheMEOWgamist
PC Specification: AMD A8-5600K, GTX 780 SC, Windows 7
Crashes on startup (Failed to Initialize Product)
Sun Aug 23, 2015 3:31 am
All was working fine until I didn't use the software for a while, tried it today and this popped up:
https://gyazo.com/ea3929be2b6cda03a66903e5099594d9
Everything is installed in the default location..
https://gyazo.com/c1b1da80ce8deef9e2979375db924c4c
Re: Crashes on startup (Failed to Initialize Product)
Mon Aug 24, 2015 11:43 am
If your Action! has been installed into Program Files x86 please move the Mirillis catalog to Program Files then.
TheMEOWgamist
Tue Aug 25, 2015 12:42 am
Thank you! Didn't realize that would have made a difference, This has been the only Game recorder that has truly worked for me.
