MrTra1tor
What's the bitrate of Action!?
Fri Aug 28, 2015 3:01 pm
I've recently heard that the best render quality is to render the video in the same bitrate as you recorded the video in, but the problem is that I have no idea what the bitrate is.
I have every setting maxed out in MP4 AMD APP and bitrate to max and quality to High.
Specs:
* CPU: Intel Core i5-3570
* GPU: R9 280X
* RAM: 12GB 1600MHz
* OS: Windows 10
StrifeCE
PC Specification: Windows 7 Home Prem, (64)
Re: What's the bitrate of Action!?
Fri Aug 28, 2015 4:23 pm
according to the files i have recorded, the bitrate is alwasy between 26-29k (with varying video durations). thats over an average of 10 videos i have currently have sitting, unedited. hope this helps
MrTra1tor
Fri Aug 28, 2015 5:18 pm
StrifeCE wrote:according to the files i have recorded, the bitrate is alwasy between 26-29k (with varying video durations). thats over an average of 10 videos i have currently have sitting, unedited. hope this helps
Where can I check it?
This helped a lot, thanks!
StrifeCE
Wed Sep 02, 2015 12:51 pm
i just went to my recordings folder right clicked on a few and pressed media info.
