bg1993
PC Specification: Intel i7-5820K, Windows 8.1, GTX 980ti
Recording Stops Automatically in Adobe Premiere Pro CC2015
Sat Aug 29, 2015 8:44 pm
Hey Action! Forums,
I just purchased and installed Action! today and was testing it out on the applications I plan on recording: Adobe After Effects CC2015, and Adobe Premiere CC2015.
Internet and After Effects record just fine, but the moment I jump into Premiere and click any part of the Premiere UI the recording stops. I can import a clip into the project pane, but the moment I click to watch the clip in any way the recording stops automatically. Really strange.
I tried reinstalling and deleting the registry keys, doesn't change it.
I tried messing with the specs and it doesn't change it.
My computer should be able to handle it with no issues, here's my specs:
Intel Core i7-5820K CPU @ 3.30GHz
32 GB DDR4 RAM
Geforce GTX 980TI Graphics Card
Windows 8.1
Recording Settings that I'd like to use:
AVI
Original (Desktop region stops the same way)
60 fps
What gives? How do I stop it from automatically stopping the recording?
60 fps
