Splash viewer
PC Specification: hp quad win 7 ultimate
How to run Action as non admin?
Thu Sep 03, 2015 11:44 pm
I saw this option: Added possibility to run Action! without administrative privileges on non-Administrator user accounts and guest account
But how?
I can not find a option.
Thanks.
Claunator
Re: How to run Action as non admin?
Sat Sep 05, 2015 11:34 am
I think it should as simple as double clicking the exe on the folder.
To make sure it's as non-admin, right-click on the exe and go to Properties, and from there go to Compatability. There, check if the "Run as admin" option is unticked. If not, untick it.
Also if i remember correctly, the newest exe doesn't have the UAC icon on it anymore, which means u should be able to run it as non-admin without hesitation.
Splash viewer
Sat Sep 05, 2015 12:21 pm
Claunator wrote:I think it should as simple as double clicking the exe on the folder.
I have the latest version, and the box is not ticket but still the uac prompt.
Splash viewer
Sat Sep 05, 2015 6:16 pm
Still UAC asking
No admin
Claunator
Fri Sep 11, 2015 7:50 am
No idea then. All i can think of is disabling UAC from the control panel.
