Buffometer
Contact: ICQ
Action and very old quests through ScummVM
Sun Sep 06, 2015 1:21 pm
In 1.22 version It was the following changes "Adaptive/Variable framerate video recording".
Games running through scummvm have variable frame rate, in the static scenes drops to 28-30, in dynamic increases to 50-60.
Everything will be fine if the record 30 frames(dynamic scenes will be not as smooth as at the 60 fps), but at 50/60 frames in dynamic will be smooth, in static and a small amount of movement - jerky, due to lack of fps, the ideal solution to this problem - variable frame rate recording.
In scummvm i used OpenGL mode, recorded in .fic (avi) and mp4 (nvenc), action does not determine the variable frame rate in OpenGl mode and record with constant fps, as a result, it is impossible to smoothly record at 50-60 fps in scummvm with action.
Frame comparison at unlocked fps in ScummVM, action recording at 30 fps, game Ringworld Revenge of the Patriarch and other old games too:
http://screenshotcomparison.com/comparison/141660
Оk, vfr not good for record, through video driver i limited frame rate to constant 30 fps, other problem, at cfr fraps recording much smoother(and correctly) than action.
http://screenshotcomparison.com/comparison/141662/
One or two skipped for this short example, other correct, in the rest of the video periodically from time to time will be 1-2 skipped frames.
