ItsReneee
PC Specification: Windows 8
Framerate
Sun Sep 13, 2015 9:23 am
I need help!
I try to record videos in 720p and 60fps with a facecam.But whenewer I finish the recording it says the video is in 30fps I tried re installing action and it didn't help.I can't figure out what the problem is.If anyone could answer that'd be great! :D
-Rene
Re: Framerate
Tue Sep 15, 2015 4:02 pm
Check if your LIVE streaming option is enabled. If yes, disable it.
