MarTxelo
PC Specification: Athlon II x4 620, XFX 9800GT, Win7 x64
Opinion
Sat Jul 03, 2010 1:17 pm
First of all, Congratulations!
You have made a great player. I have changed KMplayer & Bsplayer by Splash Lite to view films in HD.
I want to explain all of you my experience with the pro version.
-- Pros:
- CPU compensation by core when you are using it without GPU aceleration is very good: other players force one core.
- GPU Aceleration: Great! CPU use decrease to 4-5% or less
- Simplicity: I don't need to be System Programmer to enter in the configuration section. Other players make me crazy when I want to do some changes to try something XDD
-- Fails and suggestions:
- The pointer! How can I hide it? It is posible?
- Audio compensation to increase the volume, for example.
- More display formats: the player should have more options. With other players you can "play" more with this options. Is very usefull when yuo have a film with a rare video format and you want to display in your new LCD :mrgreen:
Sorry but my English isn't very good. I hope I explained well.
Regards from the Basque Country !!!
Re: Opinion
Mon Sep 20, 2010 3:26 pm
Thanks for suggestions and feedback!
