hej
Action! doesn't show video in Sony Vegas
Tue Sep 22, 2015 10:49 am
Some months ago Action! started making mp4s that no longer worked with Sony Vegas. I deleted a lot of footage because of this but I found a solution later. The issue is that the container Action is making is not compatible with Sony Vegas. However, in the past, all these video files worked perfectly.
Here is a video of the problem, I hope you can put out an update that fixes this in the near future.
https://www.youtube.com/watch?v=EwI9Bij-qzM
Also my system specs are:
Win 10 pro x64 (also same problem on Win 8 pro x64)
AMD CPU and GPU
This happens whether it is CPU or GPU encoding.
erucolindo
PC Specification: Intel i7 4790, Nvidia GTX670 SLI
Re: Action! doesn't show video in Sony Vegas
Fri Sep 25, 2015 6:11 am
I hade the same problem, and so does many other it seems. Are you trying to record multiple audio streams? That was the issue for me. Vegas only seems to parse the first two streams in a file.
The fix was to switch out the dll that was parsing the .mp4 files in vegas (I think to qt7plug.dll?). Anyways, I'll try to look up the exact fix when I get home tonight.
hej
Fri Sep 25, 2015 9:13 am
I'd love to see your fix.
The issue happens for me when I record microphone into separate audio track.
PepperBelly
PC Specification: Intel Core i5 2500k, GTX 770, Windows 7
Thu Oct 01, 2015 1:21 am
I actually made a post about this back in July. - http://forum.mirillis.com/viewtopic.php?f=36&t=37256
Had no response. It's a GLARING issue. I've stopped using Mirillis Action because of this. I've tried other programs, and Bandicam offers the same feature set, while still importing the MP4 video. So I'm using that and ShadowPlay until Mirillis gets their sh*t together and addresses this somehow.
hej
Sun Oct 04, 2015 7:43 am
[quote="PepperBelly"I've stopped using Mirillis Action[/quote]
I also ended up buying Bandicam when Action! failed me with some other stuff. Too bad, I really like ctrl+delete for making frag movies.
erucolindo
Mon Oct 05, 2015 8:12 pm
Sorry it took a long time to respond. Been busy.
Here is the fix that worked for me: https://www.youtube.com/watch?v=f5n6IeBCw3A
Do note that downloading dll's from the internet is dangerous.
PepperBelly
Tue Oct 06, 2015 4:19 am
erucolindo wrote:Sorry it took a long time to respond. Been busy.
This "fix" isn't really a fix, it's merely a workaround to a problem that was implemented in later versions of Action. Action! is at fault here. We already established what the issue is, Mirillis just has to fix it in a future update.
hej
Tue Oct 06, 2015 8:37 am
erucolindo wrote:This "fix" isn't really a fix, it's merely a workaround to a problem that was implemented in later versions of Action. Action! is at fault here. We already established what the issue is, Mirillis just has to fix it in a future update.
The problem would, first, need to be acknowledged. So far Action! has not even acknowledged that this problem exists for a time period that's approaching three months from the first user report.
Tue Oct 06, 2015 3:13 pm
Noted. I have forwarded this to the devs.
PepperBelly
Fri Oct 09, 2015 5:38 pm
radi wrote:http://forum.mirillis.com/viewtopic.php?f=36&t=37256
Much appreciated. However, I hope this time it's different. The same was said whenever I sent an email to the support team back when I posted that thread. Since then there has been roughly 6 updates, all of which never included a fix.
