Scouting
PC Specification: Windows 10
How to reset your Action setting to default?
Wed Sep 23, 2015 2:27 pm
I really want to reset my settings to default.
Re: How to reset your Action setting to default?
Fri Sep 25, 2015 6:53 am
Try following steps below to completely re-install Action. You will need your serial number to activate your product again.
1. Uninstall Action!
3. Remove Action! catalog.
4. Reboot your PC.
5. Install Action! again. Make sure that your installer file comes from official website - www.mirillis.com (if you have not purchased Action! through Steam).
