DANSER
PC Specification: APU A10-7850K, HD 7850K, WINDOWS 10 X64
¿I Can Select Integrated or Dedicated GPU?
Fri Oct 02, 2015 6:02 pm
Hello. I have a doubt.
I have an APU A10-7850k that brings integrated graphics r7 250 and also have main GPU HD 7850. My question is, How Mirillis can select which GPU to use (integrated or dedicated) to record using AMD APP?
Re: ¿I Can Select Integrated or Dedicated GPU?
Tue Oct 06, 2015 3:18 pm
Have you tried checking this under Catalyst settings for 3d application settings?
