MrTra1tor
AMD R9 Fury X performance issues during recording
Sat Oct 03, 2015 1:06 pm
I get pretty big FPS drops while recording, sometimes even up to 80 FPS!
I'm still above 60 FPS in most games, but for demanding and not-so-optimized games it could be a problem.
Is there a way to completely remove the CPU usage and purely use the GPU to record? Because it still uses a lot of the already bottlenecking CPU when my GPU is at like 60% usage.
Re: AMD R9 Fury X performance issues during recording
Tue Oct 06, 2015 3:18 pm
Please post a DxDiag report of your PC.
the9quad
PC Specification: i7 4930k, 3 X 290x's, Windows 10 64 Bit
Wed Oct 07, 2015 5:17 am
MrTra1tor wrote:I get pretty big FPS drops while recording, sometimes even up to 80 FPS!
Use AMD APP....
MrTra1tor
Wed Oct 07, 2015 7:19 am
Use AMD APP....
I do.
platinumsteel
PC Specification: core i5 2500K,ATI Radeon 7970,Windows 7
Wed Oct 14, 2015 11:10 am
Hi pal..I have the exact same problem with my ATI 7970..Would usually be getting 90fps + ...then the minute I hit the record button on Mirillis it goes all the way down too under 60fps...And i start to get lag spikes..This never used to happen to me before on my current system..It was after the last 3 or 4 updates the app started to do this.I tried win7.win8.win10..older ATI drivers Newer Ones..Same thing..Sent dxdiag reports to Mirillis support they don't even know what's up...So i have totally given up and currently looking into Nvidia Graphics with Shadow play that is flawless..And won't be renewing my mirillis license when it expires soon...cause I would have no use for it.
MrTra1tor
Fri Oct 16, 2015 6:53 pm
radi wrote:Please post a DxDiag report of your PC.
I guess I have to do a copy/paste since .txt files aren't allowed:
System Information
Time of this report: 10/16/2015, 20:46:26
Machine name: DATOR
Operating System: Windows 10 Pro 64-bit (10.0, Build 10240) (10240.th1.150916-2039)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz (4 CPUs), ~3.4GHz
Memory: 12288MB RAM
Available OS Memory: 12232MB RAM
Page File: 4101MB used, 9987MB available
Windows Dir: C:\WINDOWS
DirectX Version: 12
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Not Available
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.10240.16384 64bit Unicode
DxDiag Notes
Display Tab 1: The file aticfx64.dll,aticfx64.dll,aticfx64.dll,amdxc64.dll,aticfx32,aticfx32,aticfx32,amdxc32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Display Tab 2: The file aticfx64.dll,aticfx64.dll,aticfx64.dll,amdxc64.dll,aticfx32,aticfx32,aticfx32,amdxc32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: AMD Radeon (TM) R9 Fury Series
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x7300)
DAC type: Internal DAC(400MHz)
Device Type: Full Device
Device Key: Enum\PCI\VEN_1002&DEV_7300&SUBSYS_0B361002&REV_C8
Display Memory: 10185 MB
Dedicated Memory: 4069 MB
Shared Memory: 6116 MB
Current Mode: 1920 x 1080 (32 bit) (144Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: PHL 242G5
Monitor Id: PHLC0C4
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: Displayport External
Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,amdxc64.dll,aticfx32,aticfx32,aticfx32,amdxc32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1404 (English)
Driver Version: 15.201.1151.1004
DDI Version: 12
Feature Levels: 12.0,11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 2.0
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 9/30/2015 08:22:42, 1458144 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
Device Identifier: {D7B71EE2-3040-11CF-CE76-3C2B76C2C535}
Vendor ID: 0x1002
Device ID: 0x7300
SubSys ID: 0x0B361002
Revision ID: 0x00C8
Driver Strong Name: oem46.inf:cb0ae414a50fc953:ati2mtag_R7000:15.201.1151.1004:pci\ven_1002&dev_7300&rev_c8
Rank Of Driver: 00D12000
Video Accel: ModeMPEG2_A ModeMPEG2_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeVC1_VLD DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{A491560E-FFE4-4202-9B1D-2DCD004EB9E3}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Monitor Model: PKB MAE220W
Monitor Id: PKB5054
Native Mode: 1680 x 1050(p) (60.003Hz)
Output Type: DVI
DDI Version: 12
WHQL Logo'd: No
Vendor ID: 0x1002
Device ID: 0x7300
Revision ID: 0x00C8
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (5- USB PnP Audio Device)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: USB\VID_0C76&PID_1617&REV_0100&MI_00
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: USBAUDIO.sys
Driver Version: 10.00.10240.16384 (English)
WHQL Logo'd: Yes
Date and Size: 7/10/2015 12:59:36, 131584 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Realtek Digital Output (Realtek High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0887&SUBSYS_10438445&REV_1003
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.7553 (English)
WHQL Logo'd: Yes
Date and Size: 8/28/2015 23:38:48, 4514008 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
Cap Flags: 0xF1F
HW Memory: 0
Description: 1 - PHL 242G5 (2- AMD High Definition Audio Device)
Hardware ID: HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1007
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: AtihdWT6.sys
Driver Version: 10.00.0000.0001 (English)
WHQL Logo'd: Yes
Date and Size: 7/22/2015 01:42:04, 102912 bytes
Other Files:
Driver Provider: Advanced Micro Devices
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (5- USB PnP Audio Device)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Video Capture Devices
Number of Devices: 0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Gaming Keyboard G105
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC248
FF Driver: n/a
Device Name: USB PnP Audio Device
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0C76, 0x1617
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x1E26
| Matching Device ID: USB\ROOT_HUB20
| Service: usbhub
| Driver: usbhub.sys, 7/24/2015 05:30:58, 498016 bytes
| Driver: usbd.sys, 7/10/2015 12:59:39, 29536 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0024
| | Matching Device ID: USB\Class_09
| | Service: usbhub
| +-+ USB Composite Device
| | | Matching Device ID: USB\COMPOSITE
| | | Service: usbccgp
| | | Driver: usbccgp.sys, 7/10/2015 12:59:39, 159072 bytes
| | +-+ USB Input Device
| | | | Matching Device ID: USB\Class_03&SubClass_01
| | | | Service: HidUsb
| | | | Driver: hidusb.sys, 7/10/2015 12:59:38, 38400 bytes
| | | | Driver: hidclass.sys, 7/10/2015 12:59:38, 153088 bytes
| | | | Driver: hidparse.sys, 7/10/2015 12:59:38, 39936 bytes
| | | +-+ HID Keyboard Device
| | | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | | Service: kbdhid
| | | | | Driver: kbdhid.sys, 7/10/2015 12:59:38, 36864 bytes
| | | | | Driver: kbdclass.sys, 7/10/2015 12:59:38, 62304 bytes
| | | Vendor/Product ID: 0x0738, 0x1705
| | | Service: HidUsb
| | +-+ HID-compliant mouse
| | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | | Service: mouhid
| | | | Driver: mouhid.sys, 7/10/2015 12:59:39, 32256 bytes
| | | | Driver: mouclass.sys, 7/10/2015 12:59:39, 59232 bytes
Gameport Devices
PS/2 Devices
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 19.9 GB
Total Space: 56.7 GB
File System: NTFS
Model: KINGSTON SV300S37A60G
Drive: D:
Free Space: 4.0 GB
Total Space: 183.9 GB
File System: NTFS
Model: HDT722520DLA380
Drive: E:
Free Space: 1.1 GB
Total Space: 6.9 GB
File System: FAT32
Drive: F:
Free Space: 169.4 GB
Total Space: 953.9 GB
File System: NTFS
Model: ST1000DM003-1CH162
Drive: H:
Free Space: 167.1 GB
Total Space: 1907.7 GB
File System: NTFS
Model: ST2000DM001-1ER164
