hubsmash
PC Specification: i7-4790k, GTX 970, Windows 10
Increase Bitrate using MP4 (NVENC)
Fri Oct 09, 2015 6:36 pm
Hello!
I absolutely love the product, so thanks very much!
However, I'd very much like to increase the bitrate that it uses when doing NVENC encoding.
Currently, it seems to use a variable bitrate that maxes out somewhere around 30 Mbps.
I’d very much like to bump this up to the 50 Mbps area, or even perhaps higher. I’m noticing artifacting of the image at 1080p 60 fps and while it isn’t extremely pronounced, I do want to bring the quality up before exporting it to YouTube without using software encoding and destroying me performance in game.
I currently have the quality slider and the bitrate set to the highest they can go.
Thanks very much in advance for any assistance you can provide.
I should mention I'm using a GTX 970 and the card should be totally fine to do 50 Mbps or higher considering shadowplay itself allows much higher than that.
