GEonWAR
PC Specification: FX8350, R9 290x, Windows 10 pro
Action 1.28 error on install
Thu Oct 22, 2015 12:32 am
I saw notification of Action update, while updating I got error "Error opening with action_x86.dll". Choose ignore (retry not working) and now I can't open getting error 103. Error screenshot attached. I am trying now clean install and still getting error opening file (same file). This installer is same as Radi suggest before.
OS: Windows 10 pro (Admin right given)
Kindly provide some solution.
action error.jpg (70.24 KiB) Viewed 9662 times
josht463
PC Specification: Windows 10
Re: Action 1.28 error on install
Fri Oct 23, 2015 2:45 pm
Hello, I just had this same problem as well and here is how I managed to do it.
NOTE: You will need to have your registration key
1. I had to go into the program files and delete everything in the Mirillis Folder (or click on the uninstall app inside the folder)
2. I noticed that the "action_x86.dll" could not be deleted, and it said that it was protected by VProtect. I opened up my task manager and ended the task called "VProtect"
3. Now I could delete that previous file "action_x86.dll"
4. Then I had to go to the mirillis website and download the newest version through trial. This will then download it all fully without that error code. (You might be able to just re-run your old installation version)
5. Finally, type in your registration code that you should've kept through email and the whole thing should be working again.
This is how I've just managed to get mine back working literally 10 minutes ago. I looked on this forum as I was struggling but managed to work it out myself and thought I'd make an account on here to let you know
