Fatcamp
PC Specification: i5 2500k,8GB, amd 280, W7 64-bit sp1 ult
Mirillis makes Dota2 crash
Sun Nov 01, 2015 1:34 pm
OS: Windows 7 64-bit sp1
Video Card: ASUS R9 280 DirectCU II TOP
Memory: 8 GB
Monitor Resolution: 1920x1080,
Video Editor: none
Game Problem: Dota 2
Video Type: Dont matter
So the problem i have is if i try to load up dota2 while mirillis is running dota 2 starts up later tabs out automaticly and at this point the game crashes. I had earlier 1.27 version of mirillis but now i tried with 1.28 and same problem.
Im using a asus xonar dx soundcard
3d soundengine = Xear3D DS3D
Sound drivers version = 7.0.8.1821.
sound controller = xonar audio processing unit.
DirectX version = directX 11
GX= 1.0.12.106
ASIO= 2.0.0.12
Asus xonar dx Audio center = 0.3.0.62
for my graphiccard im using
version 15.9.1 Beta
im putting in my dxdiag if you want any other information.
http://pastebin.com/Qj7AFQ9s
I tried changing diferent soundcards etc but nothing helps
and in dota2 i have
sound device on speakers for asus xonar
speaker configuration headphones.
play sound in desktop is on
high quality audio is on.
If you want any more info just reply and i will try to give it.
