PakoWako
PC Specification: Intel Core; Windows 7; 64Bit; G-Force
Action sound doesnt sync with video
Mon Dec 07, 2015 10:12 am
Hello evryone,
I dont know why or how it comes but my audio doesnt sync with the video, example if i shoot there is a delay for 2-3 secs before you hear the audio and the audio is extremely low on a video. The first secs it seems the audio is sync with the video but after 5-6 secs you see his mouth talking but the sound comes later... I dont know what to do, is it about my settings? My computer? What do i have to do? Do i need to separate the audio and sync myself? And what can i do about making the sound higher?
- I do not separate audio with the video.
- Have this problem on evry game.
- Audio is xtremely low.
Heres a example of a video from me:
https://www.youtube.com/watch?v=4lq9yqpZRRQ
I hope you can help me out.
Grtz,
PakoWako
Messiah93
PC Specification: R5 2600 OC | 2x16gb | GTX1650S OC
Re: Action sound doesnt sync with video
Fri Dec 18, 2015 5:50 pm
I have the same problem with MP4 (Nivida).. But i don't have this problem with AVI.
Messiah93
Fri Dec 25, 2015 4:05 pm
Could we have an answer please?
sweduck75
Mon Jan 04, 2016 9:09 am
I had a similar problem. Got the advice to change Microphone and System Sounds to "System default" and then it worked. Might not help for everyone but it's worth trying.
sweduck75
Mon Jan 04, 2016 9:12 am
Messiah93 wrote:Could we have an answer please?
As I've learned, the forums isn't for straight up support but more of a more casual help. If anyone have problems with the software, it's better to just contact the Support-team on https://mirillis.com/en/support/customer_support.html.
PakoWako
Wed Jan 06, 2016 1:00 pm
sweduck75 wrote:I had a similar problem. Got the advice to change Microphone and System Sounds to "System default" and then it worked. Might not help for everyone but it's worth trying.
Okej that's a try worth, going to try that right now out lets hope it works :?
*edit* Did a sound test in game for 1 min and 16 secs, and it worked great thanks allot buddy! 8-) :D
*edit 2* Thought it worked but when i created a video for 20 mins long it wasnt, but it seems it sync a little bit better on default sound but not how it should to be.
- Now on start it seems good synced.
- The longer the video goes the worser the sync is.
- My microphone is/was always good synced.
- After 5 mins delay when shooting is around a second, after a time it is 8-9 secs delay.
Anyone else have other suggestions?
Thanks in advance.
Messiah93
Mon Jan 18, 2016 2:39 am
I have installed windows 7 (windows 10 before) and no problems now... :?
