P.J
Problem with 4K H.264
Sat Jan 30, 2016 11:19 pm
I have just tried to play this file but Splash 2.0.1 crashed :?
Video link: http://demo-uhd3d.com/files/uhd4k/Sony_ ... est-4K.mp4
Code: Select all
General
Complete name                            : Sony_Alpha_7R_II_video-test-4K.mp4
Format                                   : XAVC
Codec ID                                 : XAVC
File size                                : 1.08 GiB
Duration                                 : 1mn 34s
Overall bit rate mode                    : Variable
Overall bit rate                         : 98.4 Mbps
Encoded date                             : UTC 2015-06-04 10:40:51
Tagged date                              : UTC 2015-06-04 10:52:50
©TIM                                     : 00:00:00:00
©TSC                                     : 24000
©TSZ                                     : 1001
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L5.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 2 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 1mn 34s
Bit rate mode                            : Variable
Bit rate                                 : 96.6 Mbps
Maximum bit rate                         : 126 Mbps
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.486
Stream size                              : 1.06 GiB (98%)
Language                                 : English
Tagged date                              : UTC 2015-06-04 10:40:51
Color range                              : Limited
Color primaries                          : BT.709
Transfer characteristics                 : IEC 61966-2-4
Matrix coefficients                      : BT.709
Audio
Format                                   : PCM
Format settings, Endianness              : Big
Format settings, Sign                    : Signed
Codec ID                                 : twos
Duration                                 : 1mn 34s
Bit rate mode                            : Constant
Bit rate                                 : 1 536 Kbps
Channel(s)                               : 2 channels
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Stream size                              : 17.3 MiB (2%)
Language                                 : English
Other
Type                                     : meta
Duration                                 : 1mn 34s
MirceaForce
PC Specification: i7 5960x gtx 1070 windows 10 v1709 x64
Re: Problem with 4K H.264
Sun Jan 31, 2016 10:09 am
same problem here :)
Akura
PC Specification: Xeon1231v3,ASUS GTX960 4GB,Win7x64, 32GB
Sun Jan 31, 2016 11:10 pm
Same here. I would guess, it's because of XAVC Codec and a too high bitrate.
But no problems here in PotPlayer Portable. :)
:idea: Also I think, they maybe should add an Info in the Tab "System Requirements", which GPU is minimum required for smooth (VPU decoding..better known as "Hardware Acceleration",...otherwise it's only hybrid decoding via CPU + GPU Shader) Ultra-HD 1 & 4k Playback in H264 & HEVC/H265 and 30fps and/or 60fps.
https://en.wikipedia.org/wiki/Nvidia_Pu ... reVideo_HD (http://ogy.de/GMv2)
https://en.wikipedia.org/wiki/Unified_V ... oder#UVD_5
https://en.wikipedia.org/wiki/Intel_Qui ... o#See_also
P.J
Mon Feb 01, 2016 4:23 pm
GTX 950/960 are the best!
P.J
Sat Mar 26, 2016 4:43 pm
Still no fix?
P.J
Wed Mar 30, 2016 7:45 pm
v2.0.3.0
Even PowerDVD 15 can play it :?
Return to “Splash 2.0”
