Lightningstorm23
PC Specification: HP laptop Windows 10 2015 model
How to use TimeShift File
Fri Feb 19, 2016 10:44 pm
The other day I was playing on some COD and I get a triple headshot! So I timeshifted the file so I could prove that I did. My problem is this; how can I use a timeshift file? I cannot open it in sony Vegas, windows media player, I can't extract it either, what do I do with it? Zip it?
Re: How to use TimeShift File
Mon Feb 22, 2016 6:13 pm
Time-shift feature should create a video file (like a regular recording) in your video library.
Lightningstorm23
Fri Feb 26, 2016 1:46 am
The File has been saved
Cannot open in Action! Player
cannot open in Splash 2.0
Cannot be open in Sony vegas Pro 13
How do I use this file?
hej
Fri Feb 26, 2016 4:55 am
I'd like to help but you make it hard by omitting the single piece of information that could be useful:
The file itself. Not how programs can't open it but some information on the files in question. Are they 0kb files? Are they large files?
Since at least 2015 Action! has had a tendency to improperly contain video files so you may have the audio and info but its just in a broken .mp4 container and needs to be remuxed. (see here: https://www.youtube.com/watch?v=BwzBw9B8RqI) We've been asking Mirillis to fix it but you can guess how that went...
The other possibility is that they're 0kb files and that you lost your video and its gone and you will never get it back.
cipherhawk
PC Specification: GTX 1080, WIN10, INTEL I7
Sun Apr 08, 2018 7:17 pm
I actually have been having the same issue (on the latest version). It spins up a buffer file but does not record anything.
I did manage to get one or two recordings while I was playing Overwatch, but it timeshift recordings would sort of scrunch the video, here is a link to the video:
https://d.pr/v/OlyZju
I also heard someone solved this issue by uninstalling and removing the registry keys for the application and the reinstalling it, but this is something I have not confirmed myself.
I am thinking of just submitting a support request and see if someone with the support staff can help with this issue.
Wed Jul 11, 2018 5:47 am
Hello, it may be something with the video drivers. But try reinstalling Action! first.
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
