marciomachida
Action not detecting windows 10 games
Thu Feb 25, 2016 3:46 pm
Action not detecting windows 10 games, I need to record in window mode with "region" record.
hej
Re: Action not detecting windows 10 games
Fri Feb 26, 2016 4:26 am
what games?
Alienzone51
PC Specification: i7 4790K, G1 GTX 970, Windows 10
Sun Feb 28, 2016 8:35 pm
Same problem for me. I try to record The Witcher 3 in "Games and Applications mode" but action! wont detect it as a game. Currently using Win10, but it worked when I had Win8. It says it records for one second but then shuts Down the recording and it has not recorded anything.
Molda22
PC Specification: Intel Xeon 1231v3, GTX 970, WIN 10 64b
Fri May 20, 2016 7:10 pm
I have the same problem, lots and lots and games on windows 10 cannot be recorded at all with Action. Few games work, but the HUD is not visible. Only small amount of games work without problems. Windows 10 is more than a year old OS, so i was sure when i switched to WIN 10 from 7 month ago, that Action will be working without problems.
But it looks like its not working with most games which is very bad thing for me because i need to record almost daily.
Dobs
Thu May 26, 2016 12:27 pm
Set to record desktop...only way I found to make it work....that was before 1.30.3...now the POS software doesnt work at all..... sigh..
Manageri
PC Specification: i5,8Gbram, R9 200series, Windows 10,Dx12
Sat May 28, 2016 3:08 am
Same with warhammer and I think it does crash game quite frequently. I never crashed without Action.. :(
Manageri
Sat May 28, 2016 3:15 am
Any word from devs? Are you working on this? When we could get it fixed(ETA)?
This seem to be problem at any computer now with win 10(dx12) games...
Molda22
Sat May 28, 2016 1:39 pm
I hope that they are at least working on it and know what is wrong about it when they are not responding here to our comments.
Molda22
Mon Jun 06, 2016 5:01 am
Will devs at least say something about this big issue??? Avoiding the problem is not the solution guys. I have paid for your product and i expect at least some kind of reaction! thanks
Dobs
Wed Jun 15, 2016 7:35 pm
Punt!
