LeKris
PC Specification: Intel Core i7, Windows 10 x64 , 16GB RAM
Issues with AVerMedia Live Gamer Portable
Thu Mar 10, 2016 9:35 pm
Hi there,
last week I bought the AVerMedia Live Gamer Portable(LGP).
After installing the drivers, the REC Central Software and the LGP Stream Engine,
Mirillis Action! won't start up at all. I am using version 1.30.0, Windows 10 x64
and had no errors (neither the UAC thing nor ERROR 106) since then.
Are there any known issues or conflicts with the AVerMedia LGP?
For me it is not very comfortable to install, deinstall and reinstall
the drivers and the software.
If you have had any similar problems and or you know
how to solve it or you have a workaround,
I would apreciate it if you give me some hint, tips or advices.
Thanks in advance,
LeKris
Keep calm and play some games
Cauptain
Contact: ICQ
Re: Issues with AVerMedia Live Gamer Portable
Fri Mar 11, 2016 7:00 am
LeKris wrote:Hi there,
Thanks in advance,
LeKris
I have same problem and no workaround at now.
My Avermedia is C985 (Live Gamer). Just Stream Engine is problem.
Claudio
LeKris
Mon Mar 14, 2016 1:03 am
The Live Gamer Portable is, as far as I know the C875.
The drivers should be the same for the C985.
I installed the RECentral Version 1.3.0.104 (beta)
after installing Action! 1.30.0.
This seems to work without any problems.
So maybe the only problem is the LGP Stream Engine
which is meant to use for software which do not
support the AVerMedia products in first line like OBS for example.
