jscoys
PC Specification: Windows 10
Motion 2 and h265...
Mon Mar 28, 2016 2:36 am
Hi team! In a first time I would like to thank you very much for the great job done on H265 codec implementation!
Now I think that it needs a pass of optimisation, thought... I just tested some movies and what I can see is that it's not as fluid as H264. I know H265 is really heavy to decode, but my amd fx 8350 8 cores with gtx 950 ti 2 gigs and my 16 gigs of Ram should handle this correctly no?
So please do some optimization. You're so close to have THE perfect viseo player!
Return to “Splash 2.0”
