GamerGuy
1.30.1/2/3 less stable than 1.30.0
Sun Apr 03, 2016 8:16 pm
Using Active Screen mode for day-to-day desktop recording on fully updated Windows 10. Intel Quicksync.
I have it set to display the HUD when not recording, and the problem is under 1.30.1/2/3 often the HUD digits turn grey after stopping a recording, and then system becomes unstable afterwards requiring a reboot. Usually the digits are blue when not recording.
Had to go back to 1.30.0 for now.
aj3388
PC Specification: 2500k, 680GTX, Windows 10 x64
Re: 1.30.1/2/3 less stable than 1.30.0
Sun Apr 17, 2016 2:11 am
I think I see the same issue. The 'Desktop Windows Manager' process uses a lot more CPU with any version newer than 1.30.0. As soon as Action! is opened, all application and Start Menu actions (open, minimize, maximize..) lag. Even after Action! is closed, the actions remain laggy and Desktop Window Manager uses less but still more CPU than normal. I have to reboot to stop the lag effects.
Went back to to 1.30.0 a few days ago and have used Action! multiple times since without an issue. Windows 10 x64.
