mozkan007
PC Specification: Core i7-3610QM GeForce GT650M Win8 x64
Lipsync and subtitle adjustment settings do not work
Wed May 04, 2016 9:05 pm
Hi.I had some movies that have audio and subtitle sync problem.So I tried to solve these problems using lipsync and subtitle adjustment settings in Splash but these adjustments do not work.Because when I open the sync settings again, adjustments are still on 0 position.Briefly, Splash does not save my sync adjustments, it resets itself.Please fix it.Thanks.
ertan.kucukoglu
Re: Lipsync and subtitle adjustment settings do not work
Wed May 11, 2016 6:23 pm
Which version?
mozkan007
Thu May 12, 2016 7:34 am
v2.0.3
Return to “Splash 2.0”
