darkschneider78
PC Specification: windows 10 - super computer
Timeout connecting - unable to connect
Sun May 08, 2016 7:41 am
Using multiple connections - different ISP - VPNS -Tunnels to rule out ports no connections
I used other RDP clients
Splashtop - connected
Chrome Remote desktop - connected
Teamviewer - connected
So whats the deal Mirillis???????????????
darkschneider78
Re: Timeout connecting - unable to connect
Wed Jun 01, 2016 11:28 pm
Probably using crappy servers - during peak hours "we will see a bottle-neck effect"
assasin172 wrote:Same here,
Remote Action - Nope not at all
Well it shows device as "Online" but when i try to connect it either says No signal - Disconnect or on android it shows nothing at all !
What is this ? 19th sentury ?
Pc specs:
OS: Windows 8.1 Pro x64
GPU: Geforce GTX 950 CPU: AMD FX - 4130
Ram: 8 GB DDR3
network is good too ...
Return to “Monflo - Remote PC Access and Gaming”
