yareth alejandro
PC Specification: windows 10 2GB DDR3 64 bits
CRITICAL ERROR 103
Wed May 11, 2016 9:15 pm
Bueno, l dia de hoy estaba con la version 1.30.0 y me dijo que lo actualizara pero al actualizar me marco error y que abortara aborte quise abrir action y me marco: Failed to initialize produc please try reinstalling asi que reinicie la pc pero no me quiso abrir me dicen que al desinstalar me borrara mi clave por que yo lo compre y se me hace injusto a que no corrigan yo page un servicio para que sea desechado...
caracteristicas de mi pc:
windows 10 2GB DDR3 Memory intel HD graphics 64 bits
Re: CRITICAL ERROR 103
Thu May 12, 2016 7:03 am
Critical error 103 occurs if Action! cannot identify one of its files due to lack of digital signature or one of the file is not compatible with current version. Please try following steps below to completely re-install Action. You will need your serial number to activate your product again.
1. Uninstall Action!
3. Remove Action! catalog.
4. Reboot your PC.
5. Install Action! again. Make sure that your installer file comes from official website - www.mirillis.com (if you have not purchased Action! through Steam).
Users browsing this forum: derlean and 6 guests
