CMay
PC Specification: q6600@3.0, 4gb ddr 800, gtx275, w7x64
Feature Requests and Suggestions
Fri May 13, 2016 7:09 pm
Playback Options:
  • 120FPS Motion2 Playback
  • Checkboxes next to "Basic video controls" to easily disable or zero them out.
  • Option to bind a hotkey to a preset, or a hotkey to cycle through presets. Maybe with a small temporary tooltip that shows the name of the preset that was just switched to.
  • Add a debanding filter slider to smooth out banding in gradients caused by compression. (Example: http://forum.kodi.tv/showthread.php?tid ... #pid942551 )
  • Custom shader support?
Playlist:
  • Shuffle support.
  • Option to sort playlist by the file date.
  • Button to add folders/directories to the playlist.
  • Add context menu to playlist items. It's odd not being able to right click on them.
Settings - General:
  • Option to lock video window size to the aspect ratio of the video if in windowed mode, so there are no black bars.
Settings - Audio:
  • If there are multiple audio tracks available, try to auto-select the preferred language
About:
  • Rename "Exit" button to "Close".
jscoys
PC Specification: Windows 10
Re: Feature Requests and Suggestions
Sun May 29, 2016 12:29 pm
+1 for all these features! Not sure dev team will do something but it' sa great list of features for the next big iteration!
Return to “Splash 2.0”
