Snapper
PC Specification: AMD Phenom2, ATI 5670, Win7
Full-Screen and playback questions
Thu Jul 08, 2010 7:11 pm
Is there a way to launch the player in full-screen instead of having to hit the enter key? I didn't see anything in the settings, and I didn't see a command line option to do so. If not, it would be nice to have this added as a feature, since I am considering using this to play MKV files launched from media browser.
How will the BD version work? Will it be the same way and launch in a window rather than full-screen?
Are there any plans to allow playing from a folder rather than just files?
giskard78
PC Specification: Intel i5 650, Intel H55, Windows 7 ult32
Re: Full-Screen and playback questions
Thu Jul 22, 2010 2:10 pm
+1 :D
stream61
Sat Jul 24, 2010 6:38 am
I concur the question. +2 :D
Wonder if you can when you start the player have the full screen.
Thanks
icsterm
Contact: Yahoo Messenger
Sat Jul 24, 2010 9:22 am
good feature.
+3
giskard78
Tue Aug 03, 2010 8:33 am
Something new about this?
giskard78
Tue Aug 03, 2010 11:52 am
I temporarily solved the problem using eventghost!
Mon Sep 20, 2010 4:19 pm
We will try to include this option in future updates.
Thanks for suggestion.
verhak
PC Specification: Intel Quadcore, ATI 5770, Win7
Sat Nov 13, 2010 2:48 pm
Ghost wrote:We will try to include this option in future updates.
Can you also add other startup parameters such as (example):
•/open = Open file, don’t automatically start playing.
•/play = Start playing file as soon as player is launched.
•/close = Close player after playback (only works when used with /play)
•/fullscreen = Start in full-screen mode
•/new = Use a new instance of player
