BRMachine
PC Specification: Core i7-4790 3.6 GHz. GF GTX 960. WN7
Action! crush when I start stream on youtube
Sun May 15, 2016 4:44 pm
Sorry, I'm from Russia and do not know much English. I use google translation =)
I use the program version 1.31.2.0.
Problem:
When I run the stream (F9) on YouTube, the program immediately freezes.
When using the program's on Twitchy, everything works fine.
Intel Core i7-4790 3.6GHz
GeForce GTX 960
Motherboard ASUS Z97-K
Windows 7 Home Premium
what should I do?
Previously, all was good (Past versions of the program).
Re: Action! crush when I start stream on youtube
Mon May 16, 2016 3:58 pm
Could you post your dxdiag report?
BRMachine
Fri May 20, 2016 11:10 am
radi wrote:Could you post your dxdiag report?
Everything works in version 1.31.3.0
Thanks =)
