mbze430
PC Specification: i7-4970k - SLI 980TI - Windows 10
Action! w/ RTSS (Rivatuner Statistic Server 6.4.1)
Mon May 16, 2016 2:36 am
I am doing a trial to see if Action! will record in-game overlay using RivaTuner Statistic Server v6.4.1
I am using a GTX 980 TI with the setting to use NVENC HEVC/HVENC using MP4. I tried Original and 1080p resolution and nothing will come up from the RTSS
On the RTSS side I tried Stealth Mode ON/OFF or Custom Direct3D Support ON/OFF and Vector 3D and Raster 3D, nothing seems to put the overlay in the recordings.
Are there specific settings to get the ingame overlay from RTSS to show up in the recordings?
HarryLJones
PC Specification: windows 10
Re: Action! w/ RTSS (Rivatuner Statistic Server 6.4.1)
Tue Mar 26, 2019 12:00 pm
You can get an answer from RivaTuner.com
