InquiringMind
PC Specification: Windows 8.1
Question regarding the location of your saved Video
Wed May 18, 2016 3:14 pm
Is there a way to specify where my videos are saved? By default, they're saved onto my computer; however, I would prefer for them to be saved to my flash drive. Is there a way to change the location and if so, how do I go about doing that?
Re: Question regarding the location of your saved Video
Thu May 19, 2016 5:59 pm
I wouldn't recommend a flash drive as your video output location. Even USB 3.0 may not handle the amount that is saved to your drive during encoding. However to change your output location click on your current path in Action above the file library. You will be able to select a different folder.
