Neksis
PC Specification: i5 4670K, GeForce GTX 970, Windows 10
Action Won't Start After New Graphics Card
Wed May 18, 2016 6:50 pm
I just switched from my old Radeon HD 7970 to an Nvidia GTX 970. I tried running Action! and nothing happens.
I check the running processes and it shows that Action! bin, Action bin (32 bit) and action_svc.exe (32 bit) are running but no application appears on the desktop.
I've tried reinstalling with a complete wipe of registry entries and with my antivirus turned off.
I am a registered user but no longer have the full version install (I've contacted support about re-obtaining one). I figured that if I can't get the trial version to work then I probably won't have much luck with the full version.
Any help in getting the program running again would be sincerely appreciated.
Re: Action Won't Start After New Graphics Card
Thu May 19, 2016 5:58 pm
Did you made a clean driver installation?
