Molda22
PC Specification: Intel Xeon 1231v3, GTX 970, WIN 10 64b
Action! doesn't work in Witcher 3 on WIN10 at all!
Fri May 20, 2016 5:57 pm
OS: Windows 10 64bit
Video Card: nVidia GTX 970 (MSI)
Drivers: newest
Memory: 16 GB
Monitor Resolution: 1920x1080
Video Editor: Adobe Premiere Pro
Game Problem: Witcher 3
Video Type: AVI
Hi guys,
i am having so much trouble with Action! after i switched to Windows 10 that its crazy :cry:
Almost with every game there is some kind of problem. Mostly it was HUD being not visible (last update fixed that for Doom). But now Witcher 3 new expanison is coming shortly so i installed Witcher 3 (gog version) to prepare for it, but not only the HUD is not visible, the Action doesnt work at all!!
I cannot take screenshots, i cannot record video, nothing! When i try to capture video, each time i press the button for start and stop recording, it just creates 1 second files that cannot even be played instead of recording video.
I tried fullscreen, i tried borderless window, i tried windowed mode, nothing helps.
Please can someone help me fix that? Thank you so much for response and help.
Molda22
Re: Action! doesn't work in Witcher 3 on WIN10 at all!
Tue May 24, 2016 6:23 pm
No reply from devs?? :(
