pepijn
PC Specification: windows 10?
cant record avi
Sat May 21, 2016 11:53 pm
OS: Windows 10
Video Card: nvidia gtx 760
Memory: 16 GB
Monitor Resolution: 1920x1200
Video Editor: none
Game Problem: Desktop
Video Type: AVI
problem:
I cant change any of the settings like format screen size and fps
so now its a mp4 and is it 480p and 30fps
but in my settings it says its a avi and is 1080p with 120fps
Re: cant record avi
Mon May 23, 2016 12:04 pm
Disable LIVE streaming.
pepijn
Re: cant record avi
Mon May 23, 2016 8:37 pm
radi wrote:Disable LIVE streaming.
Thx worked :D, didnt now that that would matter because its a different tab
jameskaranu
PC Specification: i7-6700HQ 2.6GHz, NVIDIA GTX980M, WIN 10
Re: cant record avi
Tue Jun 11, 2019 11:11 pm
Apparently, in the newer versions, you cannot record in AVI. Can someone assist me?
Re: cant record avi
Wed Jun 12, 2019 5:48 am
What happens when you try to record in AVI?
GerhartRTFO
PC Specification: i7-8700/5820/3770| gtx1070/970/680 win10
Contact: YouTube
Re: cant record avi
Fri Jun 21, 2019 12:17 pm
Just noticed this after recording over 300gigs of footage. Don't know when this was changed but I had my settings to record in AVI and now that option is greyed out and I can't select it. I don't stream so that isn't the issue, I don't know what is. Also noticed that when I brought my files into Sony Vegas it can no longer play my sound file whether it's separate from the video or not. It use to be an easy drag-n-drop into Vegas with no issue.
GerhartRTFO
Contact: YouTube
Re: cant record avi
Fri Jun 21, 2019 12:40 pm
:oops: Disregard the sound issue that is user error on my part in Vegas :oops: As for the AVI being greyed out that is still an issue. Sorry for the false alarm on the sound though. . . . we good right? ;)
Re: cant record avi
Tue Jun 25, 2019 6:19 am
To record in AVI make sure to disable Time-Shift function.
ariknight19
PC Specification: Windows 8.1
Re: cant record avi
Tue Jul 09, 2019 6:19 am
oh lord i didn't see that time shift was active
thanks, it worked again :)
