Dobs
Failed to initialize. Error
Thu May 26, 2016 2:23 am
poor coding.JPG (17.54 KiB) Viewed 25393 times
I mean really?
You don't give an option WHERE TO INSTALL IT in the install. And now after updating to 1.31.3 I get this crap...
This program is losing ground rapidly.....more time fiddling with this than I am playing.
FRIGGING DON"T RELEASE ALPHA's to the paying public!!
Re: Failed to initialize. Error
Mon May 30, 2016 7:01 pm
Do you use any lowered UAC level for any other applications?
Dobs
Wed Jun 01, 2016 10:15 pm
UAC is off. No nags, no "do you really want to do this"....and if you are coding so that is required then you have lost another customer.
Fri Jun 03, 2016 1:35 pm
Could you please check if the same error message pops up if UAC is turned on?
