TheDrewdaddy00
PC Specification: Windows 7, GeForce GTX 760
Video Sound Won't Export
Tue May 31, 2016 3:56 pm
Hello! I recently recorded a long stretch of CS:GO gameplay for a YouTube channel of mine, but a problem has presented itself in the exporting process. Every time I export the video, no sound will play whatsoever in the exported film. The audio is still there in the uncompressed footage, and I'm exporting it with "Audio 1" selected, but nothing I've tried works. Can anyone help me? Thanks!
OS: Windows 7
Video Card: NVIDIA GeForce GTX 760
Memory: 16 GB
Monitor Resolution: 1920x1080
Video Editor: Vegas 13
Game Problem: CS:GO
Video Type: AVI
hej
Re: Video Sound Won't Export
Thu Jun 16, 2016 3:38 am
Sounds similar to another problem, you may solve it using the same method:
http://forum.mirillis.com/viewtopic.php?f=36&t=38336
Given that you're recording in .avi just replace all the mp4 instances with avi in the script
